Hello community !
I have a rfxcom dongle to drive my 433mhz modules : Chacon Dio cover 54754
I can send the correct frame to go up, and down, but these module don’t have a stop frame.
You have to send again the same frame to stop ( ex. when going up, send up again, when going down, send down again to stop.
Is there any simple solution i can implement to have a stop function under home assistant 2025.x ?
I have many cover to control, so a fast solution to deploy is preferred.
Under jeedom i had a simple plugin that integrate this function, now that i’m on home assistant, and i’m a bit lost.
Thanks in advance
