Change 4 names based on the status of 2 sensors
Good morning to all of you
I have a custom:button-card that changes based on the state of 2 sensors.
    if (states['switch.sensore_magnetico_cancello_chiuso'].state === "on")
      return "Chiuso";
    else if (states['switch.sensore_magnetico_cancello_chiuso'].state === "off")if (states['switch.sensore_magnetico_cancello_aperto'].state === "on")
      return "Aperto";
    else if (states['switch.sensore_magnetico_cancello_chiuso'].state === "off")if (states['switch.sensore_magnetico_cancello_aperto'].state === "off")
      return "In Movimento";
It’s working at the moment
I wanted to improve it by adding the various possibilities, but it doesn’t work.
Can you tell me where I’m going wrong?
    if (states['switch.sensore_magnetico_cancello_chiuso'].state === "on")if (states['switch.sensore_magnetico_cancello_aperto'].state === "off")
      return "Chiuso";
      return "Aperto";
	else if (states['switch.sensore_magnetico_cancello_chiuso'].state === "on")if (states['switch.sensore_magnetico_cancello_aperto'].state === "on")
      return "Da Sincronizzare";
If you need an “AND” logic:
if (… && …)
And just to clarify Ildar_gabdullin’s reply.
No extra if either.
if (states['switch.sensore_magnetico_cancello_chiuso'].state === "on") && (states['switch.sensore_magnetico_cancello_aperto'].state === "off")
it gives me an error
ButtonCardJSTemplateError: SyntaxError: Unexpected token '&&' in 'if (states['switch.sensore_magnetico_cancello_chiuso'].state === "on") && (states['switch.sensore_...'
I know too many programming languages and I think I got them mixed up here.
Try to replace && with and
unfortunately it doesn’t work
Hmm, and is normally one of these:
  • and
  • AND
Or is normally one of these:
  • or
  • OR
Case can be important!
It gives me an error in the cart
It should be &&, because it is javascript.
Maybe it is your brackets that are wrong.
if ((states['switch.sensore_magnetico_cancello_chiuso'].state === "on") && (states['switch.sensore_magnetico_cancello_aperto'].state === "off"))
type: custom:button-card
show_entity_picture: true
Show_Name: null
tap_action:
  action: call-service
  confirmation:
    text: Sicuro di aprire il cancello?
  service: script.apertura_cancello
double_tap_action:
  service: script.chiusura_cancello
hold_action:
  service: script.apertura_cancelletto
show_state: false
show_label: true
      return "Chiuso";
      return "Aperto";
this way it reads the first and second condition, but it does not read the third and fourth condition
I tested it and it works with && and the right brackets as said earlier.
    Show_Name: null
    tap_action:
      confirmation:
    show_state: false
    show_label: true
        if ((states['input_boolean.test1'].state === "on") && (states['input_boolean.test2'].state === "off"))
          return "1";
        else if ((states['input_boolean.test1'].state === "on") && (states['input_boolean.test2'].state === "on"))
          return "2";
        else if ((states['input_boolean.test1'].state === "off") && (states['input_boolean.test2'].state === "off"))
          return "3";
        else if ((states['input_boolean.test1'].state === "off") && (states['input_boolean.test2'].state === "on"))
          return "4";
I didn’t realize I had to put the parentheses.
Now everything works.
