Hello all,
I’m wondreing if it’s possible to use another port than 443.
My 443 port is used by another application.
Hello all,
You haven’t provided any info about your setup so???
HA uses 8123 are you forwarding 443 to 8123?
You could/should use a reverse proxy like Caddy and that will solve the issue (whatever it is)
I had 2 rules : 443 to 8123 and 8123 to 8123 it worked fine until i changed the router today.
In the new router, i can’t use 443. and All google home i have don’t work.
I use DuckDNS and lets’encrypt to access to my setup on HTTPS
Thank
You should use a reverse proxy.
You can try a different port say 40443 to 8123 and then append :40443 to the URL in Google etc.
I think there is a problme with my Duckdns
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] done.
[services.d] starting services
[services.d] done.
# INFO: Using main config file /data/workdir/config
ERROR: Problem connecting to server (get for https://acme-v02.api.letsencrypt.org/directory; curl returned with 6)
EXPECTED value GOT EOF
[cmd] /run.sh exited 1
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
Sounds like the issue is just a missing port.
The S in HTTPS means secure and where HTTP normally run on port 80, then HTTPS is usually run on 443.
If you to not set a port in you URL, then port 443 is assumed as default, but you can just set a port with “:”, like https://www.somedomain.com:8123
You will need port 80 to 80 for Lets Encrypt to get a certificate. If you use Caddy you can use the DNS challenge.
Lets Encrypt just need port 80 on the external side of the NAT/firewall.
Internally you can have what port you like.
With the old Haaska setup from Github it’s possible to get it working without forwarding port 443. But the instructions are verry outdated and therefore tricky.
