Change a Sensor Icon color - Very confused
Hi I am trying to set the color of an icon for a template sensor, from what I’ve read I seem to be doing it correctly but there seem to be so much conflicting information
Below is the sensor deceleration and the sensor customize
sensors:
  recycling_pickup_day:
    friendly_name: Recycling Pickup Day
    value_template: >
      {% set date_now = as_timestamp(now()) | timestamp_custom('%d/%m/%y') %}
      {% set seconds_until_midnight = ((24 - now().hour - 1) * 60 * 60) + ((60 - now().minute - 1) * 60) + (60 - now().second) %}
      {% set tomorrows_date = (as_timestamp(now()) + (seconds_until_midnight)) | timestamp_custom('%d/%m/%y')  %}
      {% set pickupday = strptime(states.calendar.recycling.attributes.start_time, "%Y-%m-%d %H:%M:%S").strftime("%d/%m/%y") %}
      {% if pickupday == date_now %}
        TODAY
      {% elif pickupday == tomorrows_date %}
        TOMORROW
      {% else %}
        {{ pickupday }}
      {% endif %}
Customize.yaml
sensor.recycling_pickup_day:
  icon: mdi:recycle
  templates:
    icon_color: <
              if (state == 'TODAY') {
                 return 'rgb(255, 255, 0)';
              else if  (state == 'TOMORROW') {
                 return 'rgb(255, 255, 106)';
              } else {
                 return 'rgb(0, 0, 0)';
try this instead. I’m not sure what language it is, but I do know that the syntax you wrote is wrong:
  icon: mdi:recycle
  templates:
    rgb_color: >
      if (state === 'TODAY')
        return [255, 255, 0];
      else if (state === 'TOMORROW')
        return [255, 255, 106];
      else
        return [0, 0, 0];
Just want to clarify, The portions that were wrong was 3 equal signs, the direction of the arrow, the way you called out the rgb_color, and the template section you placed it in. The brackets you used are valid, but they are only necessary when you have a multiple lines inside your if/else if/else statements.
Thanks I’ll give your changes a try
If you look at the customizing docs there’s no template: section.
There’s also no way to set the colour of an icon in the current frontend. You could use an icon picture instead, or have a look at Lovelace.
You may be right, I’ve seen talk about it being possible using home-assistant-custom-ui package.
I might as well just wait until lovelace matures
  templates:
    icon_color: >
      if (state < 1) return 'rgb(0,0,0)';
      if (state < 2) return 'rgb(51,0,0)';
      if (state < 10) return 'rgb(51,25,0)';
      if (state < 50) return 'rgb(102,51,0)';
      if (state < 150) return 'rgb(153,153,0)';
      if (state < 350) return 'rgb(102,204,0)';
      if (state < 700) return 'rgb(51,255,53)';
      if (state < 2000) return 'rgb(102,255,178)';
      if (state < 7000) return 'rgb(153,255,255)';
      return 'rgb(204, 255, 229)';
or
    icon_color: >
      if (state === 'on') return 'rgb(251, 210, 41)';
      return 'rgb(54, 95, 140)';
be sure to use
icon_color: > and not icon_color: <
rgb_color: isnt supported any longer for icon color templates
always check the state of the sensor in the dev-tools, and be case sensitive
I assume icon_color only works when I use home-assistant-custom-ui
I’ve made all suggested changes but still can’t change the icon color
It isn’t supported in the default UI, as I said above :wink:
you should indeed follow these very simple installation instructions first:
Did code this today, and it works fine. I prefer native functionality, but HA lacks a lot for the GUI so meantime Custom UI works fine.
AIr
FIle: custom.yaml
sensor.air_pm_25:
  templates:
    icon_color: >
      if (state < 25) return '#6ee86e';
      if (state < 40) return '#ff9900';
      if (state < 150) return '#ff0000';
      if (state => 150) return '#990099';
I am trying to duplicate this for Lovelace Glance type card, I wanted my battery sensors and temperature sensors to show different colours depending on state.
I manually installed the CustomUI as per the above instructions, I then added this to one of my entries in customize.yaml (obviously i will do more but just wanted to get it working with one first)
sensor.lounge_main_remote:
  custom_ui_state_card: state-card-custom-ui
  friendly_name: Lounge
  icon: mdi:battery-outline
  templates:
    icon_color: >
      if (state > 12) return 'rgb(0,255,0)';
      return 'rgb(0,0,255)';
However this has not made any difference. I see no errors in my log and am unsure what the next step would be?
Did you restart hass and CTRL+F5 on the web ui page?
yes did both of those and tried from a private browser as well incase a cache issue.
I don’t think i have installed it all correctly actually, as i do not see Customizer component in my configuration panel.
did you follow @Mariusthvdb’s installation instructions?
I thought i had but now rechecking it all.
I have /www/custom_ui/state-card-custom-ui.html and /www/custom_ui/state-card-custom-ui.html.gz
Also created /custom_components/customizer/ (with 2 files init.py and services.yaml)
In my configuration.yaml i added;
  extra_html_url:
      - /local/custom_ui/state-card-custom-ui.html
However this failed to give me the extra options within configuration so i removed that and tried;
customizer:
  custom_ui: local
But still nothing.
HI,
though I am by no means experienced in Lovelace yet, and don’t know if it could have to do anything with Lovelaces specifics, I read you have the custom state card added in configuration.yaml. It is however a setting to be set in frontend.
I do that by having the frontend: !include frontend.yaml entry in configuration.yaml, and have the file frontend.yaml in the /config directory, and with this content:
# https://home-assistant.io/components/frontend/#javascript_version
# https://home-assistant.io/developers/frontend_creating_custom_ui/
# https://github.com/home-assistant/home-assistant/pull/10776
javascript_version: auto
themes: !include_dir_merge_named frontend_themes
extra_html_url:
  - /local/custom_ui/state-card-tiles.html
  - /local/custom_ui/state-card-value_only.html
  - /local/custom_ui/custom-weather-card.html
#  - /local/lovelace.html
#  - /local/custom_ui/state-card-table.html
#  - /local/custom_ui/state-card-custom_scene.html
#  - /local/custom_ui/state-card-text.html
extra_html_url_es5:
  - /local/custom_ui/state-card-custom-ui-es5.html
  - /local/custom_ui/state-card-tiles_es5.html
never mind the # commented entries, this is simply to show you how to configure Ha to read the custom state cards correctly.
main point: you need frontend: set in your configuration.
yes, although not seperate like your setup i tried extra_html_url: under frontend.
my javascript_version is set to latest and i have themes as well. I then have customizer outside of this; (i understood i use either extra_html_url or customizer which is why commented out below)
# Enables the frontend
frontend:
  javascript_version: latest
  themes: !include_dir_merge_named themes/
  extra_html_url:
     - /local/custom_ui/state-card-mini-media-player.html
    # - /local/custom_ui/state-card-custom-ui.html
customizer:
  custom_ui: local
customizer: should be in the configuration.yaml.
or in a separate customizer.yaml and be referenced in configuration.yaml by:
customizer: !include customizer.yaml
# Base configuration
homeassistant:
  latitude: !secret latitude
  longitude: !secret longitude
  elevation: !secret elevation
  unit_system: metric
  time_zone: !secret time_zone
  customize: !include_dir_merge_named customize
  customize_glob: !include customize_glob.yaml
  packages: !include_dir_named packages
  whitelist_external_dirs: /config
config:
#conversation:
# Presence based lights https://home-assistant.io/components/device_sun_light_trigger/
# device_sun_light_trigger:
# https://github.com/custom-components/custom_updater
custom_updater: !include custom_updater.yaml
#debug_asyncio:
discovery:
#  ignore:
#    - ikea_tradfri
#    - philips_hue
#    - google_cast
hassio:
history: !include history.yaml
thank you, yes i did mean it was all in the configuration.yaml rather than seperate files.
I found my error, i did wget on the .gz file which was linked, instead of downloading and including a true .gz type zip it actually saved a webpage.
Now updated and seemingly working.
Many thanks for the assistance!
cool, happy customizing!
