Change a Switch state on motion if lux is below xxx
I currently have an automation to turn on a light if motion is detected
- alias: Turn on Rear Hall Lamps when there is movement
    platform: state
    entity_id: binary_sensor.rear_hall_pir_sensor
    to: 'on'
    service: switch.turn_on
    entity_id: switch.rear_hall_lamps_main_switch
- alias: Turn off Rear Hall Lamps 3 minutes after last movement
    platform: state
    to: 'off'
    for:
      minutes: 3
    service: switch.turn_off
I would like to incorporate the lux from entity: sensor.rear_hall_pir_luminance
so the light only comes on if the lux is below say 10
,many thanks
Add a condition if lux is less than 10
cheers ill give it a go
