I’m wondering whether it would be possible to change the base container image for the SSH add-on from Alpine to Debian. I ask this because I have successfully set up a remote SSH connection from a local VSCode instance to the SSH add-on, which works nearly perfectly, except that Alpine is not fully supported by the VSCode Remote - SSH extension due to limitations with the packaged musl
/ gcc
libraries.
I note that the VSCode Remote add-on is built on a Debian base, so doesn’t suffer from this issue, but the add-on has been archived, which I assume means I cannot rely on its ongoing support.
More detail about the Alpine limitation available here.
