Hello community,
Beginner in Home assistant, I try desperately to change my assumed state switch flash button.
here is my (basic) code :
switch:
- platform: command_line
switches:
fenetre_1:
command_on: echo -ne "\x01\x06\x00\x01\x05\x00\xDB\x5A" > /dev/ttyUSB0
command_off: echo -ne "\x01\x06\x00\x01\x05\x00\xDB\x5A" > /dev/ttyUSB0
friendly_name: Cuisine
fenetre_2:
friendly_name: Salon
and
homeassistant:
customize:
switch.fenetre_1:
icon: mdi:window-shutter
switch.fenetre_2:
(I will add icon state for entity later…already have this skills :-))
I already have a look about custom-ui but to be clear, i don’t find how to change these icons…
If it is so difficult, I will check for a pre-build addon.
Any suggestion for me ?
Thanks for your help.
Regards
Guillaume
use assumed_state: false
to change from the lightning bolts to a normal toggle and use device_class: garage_door
to get the icons to change for you without using crazy templating. List of device classes.
switch:
switches:
fenetre_1:
fenetre_2:
If the device class isn’t allowed for a command_line
switch you could do this in the customise GUI.
Hello Dave,
Thank you for your help.
In fact, with your suggestion, when I push UP button follow to STOP, I can’t puch UP again.
I must push to DOWN button.
With assumed state, I can push again.
Does it mean that just change my flash icon with another is not natively possible ?
Regards
Guillaume
What happens if you just use the device_class
and leave out the assumed_state
