Change background of Lovelace UI
My question’s pretty short, how can I change the background of the Lovelace UI in Home Assistant. A solid color would be fine, but I would like to do an image. I have a custom theme setup, but I’m not sure how to change the background of the UI. Any help is appreciated. Thanks
Not sure how to change it but check out the Lovelace Animated Background card in HACs. Makes it so that the background changes to an animated image that mimics the weather outside.
Edit dashboard -> raw configuation editor then add something like :
background: >-
      center / cover no-repeat fixed
      url('https://live.staticflickr.com/8047/8105512307_f11f2c4339_b_d.jpg')
I know this is older now, but I was wondering if templates are supported in here, this would allow me to use a sensor value to specify a url.
