I’m using the clear_sky skin with a photo as a background but I would love to have an automatic rotation in it by providing a list of URL’s to photos and it would change every day or week or so? Is this possible?
it is possible.
you need to create a javascript that does that and include that script in the head (see upper part variables.yaml)
i think 1 of the included skins has something like that, so you might want to take a look at it.
Also, I installed my skins through git but now when I try to add any of my own images in the img folder like where the original background image ‘background_1.jpg’ was, the file name turns up red and I can’t seem to link to them in the css? I’m using HASS Configurator to manage my files btw.
i never worked with hass configurator.
i can only tell you where your files should be and what to do with it.
in your configuration directory (where appdaemon.yaml is) you need to have a directory custom_css
in that directory you make a subdir for each skin.
those subdirs need to have 2 files, variables,yaml and dashboards.css
those files can be manipulated.
a button can be created with javascript, but not inside the dashboard (on the side top or bottom is possible)
in theory you could create a custom widget to change the background, but there is no existing 1 for that.
Actually, the latest AppDaemon beta included a JavaScript widget that should let you do exactly that - it lets you run an arbitrary javascript command when it is pressed. I can’t check now but I think it is in beta3, if not it will be in beta4.
its in the docs, so i guess the running version.
i didnt notice that one, but probably because of my english, i had/have no idea what to think by “arbitary javascript command”
i think we need to think about a little more explenation in the docs there.
