So I bought the aurora one zigbee uk double socket and have it connected via zha and if you use their hub you can adjust the led backlight brightness on the socket but when connected directly through zha I can’t seem to do it and was hoping someone could help
Hi
I was wondering if I could ask you to answer three wee queries on these sockets?
Did you find that the power monitoring worked out of the box connecting these sockets directly to HA via ZHA?
Did they show up as lights or switches (I read a thread earlier where they were showing as lights - I mean, I could go and change entity type if required, but I’d rather not have to)
Did the LED backlight adjustment end up working via ZHA?
I’m about to upgrade all my sockets and I wanted to use these, particularly as they have power monitoring.
Hi, I know this is an old post but I thought I’d answer.
1: power monitoring for Watts seems to work fine. I don’t have a second meter to test but it shows 1W for an LED bedside light and 45W for my laptop charger which seems about right.
2: It does however show 5 and 56 Amps and a 6 digit VA rating. I’ve just turned those entities off for now.
3: NO! And that’s why I’m here, searching for a solution ![]()
I’ve only had it powered up for 5 mins so far but I wouldn’t reccomend it currently.
