Wondering if there is anything special I need to do to swap my Bluetooth adapter?
The one I’m using now seems to be having issues with disconnecting so I want to swap to a supported adapter - not sure if I’ll lose all my existing integrations / pairings, or what I should do to migrate to a new adapter.
Quick follow up - anyone have thoughts / experience?
There should be no problem swapping Bluetooth dongle as long as the OS see it. You will have a problem on Linux if it doesn’t find the driver for it. You can put back the old Bluetooth without problem.
Thanks! I’m using a BCM20702A0 based adapter now so I will pick up one of the supported CSR8510A10 instead.
