Change capital letters to lower letters value_template
Hi All,
This is working:
{% set item =  state_attr('sensor.bitladon_all', 'result') | selectattr('ticker', 'eq', 'FTT') | first %}
{{ item.ticker }}
Output: FTT
But is there a way to make this to lower letters:
Output: fft
Cheers
Peter
Please try this
{{ item.ticker | lower }}
Thanks you are my hero for today… makes many automatons lots easier!!
How do I change from not_home to e.g. Away or Not Home?
- platform: mqtt_room
  name: "Kim Apple Watch"
  device_id: "xxxxxxx"
  state_topic: 'espresense/rooms'
  timeout: 5
  away_timeout: 120
  device_id: "xxxxxxxxx"
  timeout: 5
  away_timeout: 120
  name: "Nattz Apple Watch"
  timeout: 5
  away_timeout: 120
If your define the device class for these sensors, home assistant will translate the sensor states in the UI using the language of the UI.
See Binary sensor - Home Assistant
