Hey
i would like to change the Card-Color on condition. In the top left corner you‘ll find my aqara door sensors named „Wohnungstür“ and „Kellertür“. I would like to change the color of each card seperatly to red, if the state change from „off“ to „on“. Is that possible?
Thank you.
Hi, what kind of cards do you use? I think there are several ways to do what you want. My first attempt will be to use two conditional cards, one for each background:
Another option would be the config template card, where you can use templates in your card definition:
When you use the custom button card, it has an option to change the style of the card, depending on state:
Hey @tobi-bo , thank you for your help! I use simple entity-Cards. And i can not believe, that there is no option “out of the box”. Do i have to install in fact a template?
Yes, I think so. As far as I know, the standard entities card does not support any templating or changing the background color depending on state.
Hey, @tobi-bo, would you please help me? Since a lot of days i try to integrate the config-template-card. I installed it via HACS. And then the instructions don´t go into the support of beginners. Unfortunately I have no idea, how to implement a card that change his background color in dependency of the status. I can’t even find entry-level information or YouTube videos explaining how to embed.
Hi, this works for me:
type: 'custom:config-template-card'
variables:
LIGHT_STATE: states['light.lightstrip_bett'].state
entities:
- light.lightstrip_bett
card:
type: entities
entities:
card_mod:
style: >-
${ if (LIGHT_STATE === 'on') {
'ha-card {background-color: #AAFFAA;}'
else {
'ha-card {background-color: #FFAAAA;}'
Results in:
Doesn’t look pretty so far, but you have to play around with the colors
For this example card-mod must be installed, but in principle the template works at every point in the card definition.
Well… I´ve installed the card-mod and the config-template-card via HACS. And if i have a look on Ressources in the Lovelace section, both of them are shown. But if i create a new manual card and fill in the basic code,
card_mod:
style: |
ha-card {
color: red;
i´ll become a error: “No card type found”. If i fill in your code, nothing happens. The result is empty. It feels like there is any missing step… But i have no idea, what i could have forgotten…
you don’t need the template card, card mod accepts jinja templates
Oh hell… So many new things…
I tried the template card to see what happens. But do i understand you right: I have to open my existing card and need to edit the code?
My original:
cards:
- type: button
tap_action:
action: none
entity: binary_sensor.openclose_4
show_icon: false
show_state: true
show_name: true
hold_action:
action: none
icon_height: 65px
- type: button
tap_action:
action: none
entity: binary_sensor.openclose_3
show_name: true
hold_action:
action: none
icon_height: 65px
show_state: true
show_icon: false
Sorry guys! It’s just stuck with me.
- type: button
tap_action:
action: none
show_icon: false
show_state: true
show_name: true
hold_action:
action: none
icon_height: 65px
card_mod:
style: |
ha-card {
background-color: {{ '#AAFFAA' if is_state('binary_sensor.openclose_4', 'on') else '#FFAAAA' }};
Aaaahhh, got it! I thougt, that i have to use a separate card because of the HACS installations. I still have a lot to learn!
Many thanks for your help, guys! And @tobi-bo: Thank you for your patience!
Have the same kind of issue with Card Mod. I want to have a card colored if the output power of my solar panels is more than 0. I’ve created this
type: entity
entity: sensor.rdk0cev0ae_output_power
card_mod:
style: |
ha-card {
color: {{ '#AAFFAA' if is_state('sensor.rdk0cev0ae_output_power', 'state') > 0 else '#000000' }};
But for some reason this doesn't work. Can someone see what is going wrong?
Got it working ![]()
While most other answers are good I want to go a little further and give you a little more functionality to this.
card_mod:
style: |
ha-card {
{% if is_state('light.entity_name', 'on') %}
{% set light_color = state_attr('light.entity_name', 'rgb_color') %}
background-color: rgb({{ light_color[0] }}, {{ light_color[1] }}, {{ light_color[2] }}, 0.1);
{% endif %}
This supports color change of the entity in question. The idea is to get the rgb colors from the entity in a variable and use it to construct the color in css when the light is on. Note that the background will be with transparency of 10% and you might want to adjust that as needed based on your design. Have fun!
This is a significantly cool piece of code. It was exactly what I needed! Thank you!
Any idea why this does not work? No errors, it just never changes the color of the icon. If the printer is running, I want the icon to be green, otherwise it is red.
type: tile
entity: sensor.p4_print_status
icon: mdi:eye
card_mod:
style: |
.tile {
{% if is_state(config.entity, 'Running') %}
--tile-color: green;
{% else %}
--tile-color:red;
{% endif %}
Try using
card_mod:
style: |
ha-card {
--tile-color: {{ 'green' if is_state(config.entity, 'running') else 'red' }} !important;
