Change Color Temperature Presets in the More Info for a Light
in the “More Info” dialog of my lights, I can select some color temperature presets. Is there a way to change this presets, e.g. to 2700K and 3000K instead of the defaults ?
I found nothing for this in the docs.
Press and hold the presets and you should be able to modify them.
You need to be logged in as admin for this to work (not well documented)
