I have installed and set up fritz box tools (ui version) and now I need to make some changes to its config. I have created some new profile in my fritbox and want them to be exposed to HA as switches. Been searching across the entire menu but I have absolutely no idea, where I can add the names of my new profiles to the existing configuration in HA. Can anybody help?
This one is solved by the way. You need to re-add the integration. Just remove it and then add it again. You will then be able to change the config.
