Hi, It is possible to change the configuration on the fly? For example, I want to have two modes of heating for my thermostat.
floor temp
air temp.
So I need at GUI select “heating mode” and after select, I need to change the thermostat sensor entity. I can’t find any info about this in the documentation.
I got two sensors in the room, one in the floor(concrete) to monitor floor temp, second at room (air).
My original thermostat got two modes of operation floor,air.
For example, if is a select floor mode, the heating is on until the floor gets to the desired temperature and then keep floor temperature of the floor to set values.
In air mode, the floor is heating until the air temperature gets to the desired temperature, etc.
I could be good for different room types, for example, the bathroom where you want to have a warm floor.
