Change css class on entity value change
I want to set different css classes based on the current entity value.
Tried this but it’s not working.
- entity: sensor.heatpump_icon_fanspeed
              element: heatpump.fan
              state_action:
                service: floorplan.class_set
                service_data: |-
                    if (entity.state === "1"){
                      return "spinning";
                    } else {
                      return "spinninghigh";
              tap_action: false
Check to see if there are any non-numeric characters in the state. I also always parse them to a value and then do the check. So something like:
          state_action:
            service_data: |
                if (parseInt(entity.state) == 1) return "spinning";
                else return "spinninghigh";
          tap_action: false
Thank you,
Works almost perfectly.
Can I also make more cases?
           service_data: |
                elseif (parseInt(entity.state) == 2) return "spinninghigh";
Yes you can do it that way. You can also assign the state value to a variable and then check that.
speed = parseInt(entity.state)
It’s all just JavaScript
Perhaps I’m missing something.
service_data: |
        if (parseInt(entity.state) == 1) {
            return 'spinning';
        } else if (parseInt(entity.state) == 2) {
            return 'spinningmid';
        } else if (parseInt(entity.state) == 3) {
            return 'spinninghigh';
I don’t see what i’m doing wrong.
You didn’t mention what is going wrong but I can suggest that you don’t need the final IF. Just have
Else return “spinning high”;
Edit: check your indenting as well
I want to set a (different) class, when the heatpump is working. I can of ofcourse make a class for not spinning.
Made a screenshot of the code, because the editor doen’t show the indenting correct.
If I try your example it works perfectly, but mine doesn’t
everything below the javascript don’t get executed.
I can not figure out why.
I’m assuming the entity has the state of 1, 2 or 3 only.
Try double quotes around the return value
