Change Dashboard Card icon color
I’m trying to change the icon associated w/ each color of ink cartridge in my printer. I’ve read a number of threads, tried some code, and cannot get the colors.
Card:
printer-card
My code:
entities:
  - entity: sensor.hp_laserjet_200
    secondary_info: none
  - entity: sensor.hp_laserjet_200_black_cartridge_hp_cf210x
  - entity: sensor.hp_laserjet_200_cyan_cartridge_hp_cf211a
  - entity: sensor.hp_laserjet_200_magenta_cartridge_hp_cf213a
  - entity: sensor.hp_laserjet_200_yellow_cartridge_hp_cf212a
title: Printer
type: entities
state_color: false
Code I’ve tried:
    styles:
      icon:
        - color: black;
You may try using card-mod to set colors for icons.
Thread is here.
Go to 1st post → link at the bottom → styles for Entities card - > find how to change colors for icons.
Thank you. I have card-mod and tried some of the code. Maybe I need to run thru again.
Seems the below code works, though the editor is throwing an error saying visual editor is not supported…
    card_mod:
    style: |
      :host {
        --card-mod-icon-color: cyan;
Probably because you forgot indentation:
  card_mod:
    style: |
      :host {
Yep, got it right, thanks…
entities:
    card_mod:
      style: |
        :host {
          --card-mod-icon-color: black;
A bit advanced version:
type: entities
entities:
  - entity: input_number.test_level_1
    icon: mdi:circle
    card_mod:
      style:
        hui-generic-entity-row $ state-badge $ ha-state-icon $ ha-icon $ ha-svg-icon $: |
          svg {
              fill: rgba(0,255,255,{{states(config.entity)|float/100}});
              stroke: var(--state-icon-color);
  - entity: input_number.test_level_4
    icon: mdi:circle
    card_mod:
      style:
          svg {
              fill: rgba(255,0,255,{{states(config.entity)|float/100}});
  - entity: input_number.test_level_5
    icon: mdi:circle
    card_mod:
      style:
          svg {
              fill: rgba(255,255,0,{{states(config.entity)|float/100}});
Very nice… the color opacity even changes!
In addition to your nice icons I would suggest changing the sliders to something more representative like these bars:
type: custom:bar-card
title: Epson ET 3750
entities:
  - entity: sensor.epson_et_3750_series_black_ink
    color: black
  - entity: sensor.epson_et_3750_series_yellow_ink
    color: '#fab300'
  - entity: sensor.epson_et_3750_series_cyan_ink
    color: '#00cccc'
  - entity: sensor.epson_et_3750_series_magenta_ink
    color: magenta
I got this card from HACS (or Github)
Very nice, thanks!
Edit: I wish I could combine the two, but doesn’t seem like I can add card_mod to the config.
Edit 2: BTW, welcome to HA!
