Change dashboard url
So is there a way I can make the url
Http://192.xxx.xxx.xxx:8123/dash/dash
Instead of
Http://192.xxx.xxx.xxx:8123/lovelace/dash
I’m like 99.9 percent sure at some point I did this by editing some raw code but I tried editing the raw dash and I don’t think I had the option… I’m sure I’m missing something really obvious and someone is gonna be like “just do this your retarded” which, my bad 🤷
Long story, had it on an SD card, kept failing, had to use a flash drive, failed slightly less, used raspbian and a supervised docker image, no issues so far, but I have this performing automation for my mom and she’s not gonna be able to deal. Everything is bookmarked and has shortcuts to the url. Including a smart tv. Which I forget how I side loaded a short cut to her front door cam…
You need to create a new dashboard under the configuration, but the url has to have a “-” (dash) in it, so you can’t have Http://192.xxx.xxx.xxx:8123/dash/dash
I found this thread because I was looking for a way to circumvent this but no luck yet
