I have a Dreame vaccum integrated to Home Assistant, it works great for the most part. But I always need to start the device via a Shortcut which I made in the Dreame app. This is available to use in Home Assistant too. What I would like to do is to change the default play/start button in Home Assistant to run this shortcut button.robotdammsugare_shortcut_2
when I press start.
Can you change the default behaviour?
Thank you!
