I want to move my automations into several files under a sub folder and then have
automation: !include_dir_merge_list automations/
in the main configuration.yaml to pick up all files in the automations folder. This works find but if I create a new automation in the frontend GUI it gets saved to config/automations.yaml
Is there anyway to change the default location so it saves to config/automations/automations.yaml or an alternative way to do the includes so it will include both the original file and the automations folder as well?
this is exactly why my automations did not save.
i have solved it too by including the folder and the file, but now i have to look in 2 locations. so i am too interested in a way to change the default location of automations.yaml
