Hello Community! I’m absolutely new to Home Assistant – but already loving it.
My current problem: I have an IoT device, which publishes auto discovery data to MQTT. However, the device_class of one sensor is wrong. I cannot change firmware.
How would I change it in HA? And: can I?
My current attempt is to add a customize section to configuration.yaml, however, this seems to be without effect.
Is there any way to debug / find out, if the MQTT data is actually actively superseding the "customize"d values?
I initially also thought of 2.), however, soon gave up as the auto discovery data is a (more or less) complex JSON object, where I only need to change 1 key.
It’s the other way around; customize is supposed to overide the entity’s underlying integration. If it’s not happening then there’s no recourse. The reason why I had asked if you had restarted Home Assistant is because sometimes people forget to do it and their customizations aren’t loaded.
It’s admittedly a pain to have to duplicate the entire discovery payload just to change one key-value pair.
