If I turn a dimmable light to barely on, it hardly shows any color on the icon, as opposed to when it’s on at 100%. This makes the icons hard to tell if the light is on or off as i very much use my lights at a very low brightness. Based on my assumption that 1% brightness is set to a specific color near #62838D, and 100% is set to #FDD835. The frontend will then use an algorithm to pick a color in between those two based on the brightness set point. Is there a way that i could modify the color for 1% brightness to a more dark yellow color, for instance #9D8202?
Did you ever find a solution to this?
Sorry, unfortunately not. Still bugs me.
