I just started playing around with MQTT and are using the embedded MQTT broker.
It’s possible to change the MQTT port (default is 1883), but not the websocket port (8080)?
I’m already using port 8080 on the device that runs HA and the MQTT server can’t start.
Did you solve this? I am in the same situation, I’d like to run Unifi Controller Add-on, which I can’t get to wotk with another port than 8080.
I’ll answer my own post: Followed this. Works great. MQTT Embedded broker and websocket
No. I installed mosquito in a docker contrainer instead.
I’ll consider using the embedded broker if I need to change it sometime in the future.
