I already tried to change the entity name for a TRADFRI bulb. Following the instruction on
showed me the following error: save failed: Invalid entity ID
I liked to change the entity name to: “light.OG_WZ_Lampe_Decke1”. Because of the error above, this seems to be a invalid name. So I tried to “light.OG_WZ_Lampe” first. My plan was to enlarge the name piece by piece until it fails again.
“light.OG_WZ_Lampe” worked, but now the little gear in the top right corner of the is no longer there.
How do I change the entity name a second time?
Already found this post:
But searching the configuration directoy gave me only two files with the content “light.OG_WZ_Lampe”:
You need to edit the entity registry in the .storage directory.
The reason it broke is because you’re trying to use capital letters in the entity_id and unfortunately there is no error check. Use only lowercase letters.
