Change entity picture if I turn on a switch, run a script, scene etc?
Is it possible to change the entity picture if I turn on a switch, run a script, scene etc?
I’ve seen people doing it with icons for battery states (charging, not charging, charge percentage), and I’m just wondering if it’s possible to adapt something like that to my use case?
For example with this switch that turns on different scenes:
  switches:
    office_light_custom:
      value_template: "{{ is_state('office_light_custom', 'on') }}"
      turn_on:
        - service: scene.turn_on
          entity_id: scene.office_light_100
      turn_off:
          entity_id: scene.office_light_off
Is it possible when the switch is on to use:
entity_picture: /local/[email protected]
And when switched off to use (or just have this as the default icon):
You can use icon_template for that.
icon_template (Optional): Defines a template for the icon of the sensor.
Example:
    sensors:
      day_night:
        friendly_name: 'Day/Night'
        value_template: '{% if is_state("sun.sun", "above_horizon") %}Day{% else %}Night{% endif %}'
        icon_template: '{% if is_state("sun.sun", "above_horizon") %}mdi:weather-sunny{% else %}mdi:weather-night{% endif %}'
For more info look here:
Ah, so this works with ‘entity_picture’ as well, not just ‘mdi-icon-whatever’?
Thanks, I’ll look at this.
OK, I tried the code below and it didn’t work :disappointed:
(With and without quotes around ‘entity_picture: /local/[email protected]’ .)
  sensors:
    jays_desk_lamp_icon:
      value_template: '{% if is_state("switch.hs100_5_jays_desk_lamp", "on")) %}On{% else %}Off{% endif %}'
      icon_template: '{% if is_state("switch.hs100_5_jays_desk_lamp", "on") %}"entity_picture: /local/[email protected]"{% else %}"entity_picture: /local/[email protected]"{% endif %}'
Any ideas on how to get it working?
Skip the “entity_picture” part.
I tried this below. It didn’t show any errors, but didn’t show any of the images either
  sensors:
      value_template: '{% if is_state("switch.hs100_5_jays_desk_lamp", "on") %}On{% else %}Off{% endif %}'
      icon_template: '{% if is_state("switch.hs100_5_jays_desk_lamp", "on") %}/local/[email protected]{% else %}/local/[email protected]{% endif %}'
If you use the mdi icons it will work, I believe.
I use automation to turn on/off visibility of a group with one entity in it. The picture of the group is set but I think there is probably a way to have a on group and different off group for each entity. Its not the solution you were looking for but its a complicated alternative.
Yeah, I realise that. But I’m wanting to change ‘entity_picture’ not mdi icons, hence the title :slight_smile:
Yeah, thanks but that’s not what I’m after.
I think you cannot do what you want atm hence my reply, maybe put a change request in and let people vote on it? I would probably vote for it :smiley:
Yeah, I agree. I don’t think it would be possible at the moment.
I might put it in as a feature request :slight_smile:
@RobDYI can you please let me know how to show time history as it showing under Outside Motion Alert “1 second ago”?
Check this out
This is exactly what I am trying to accomplish did anyone get it done?
No, I never managed to do it.
…actually, I’ve just found out how to do this :slightly_smiling_face:
If you look at this info on Template Switches (bottom of the page) you can use ‘entity_picture_template’ to change the images.
This is what I have but does not seem to change the icon to entity
sensor.moon:
  friendly_name: Moon
  entity_picture_template: >-
    {% if is_state('sensor.moon', 'New moon') %}
      /local/images/new-moon.png
    {% if is_state('sensor.moon', 'Waning crescent') %}
      /local/images/waning-crescent-moon.png
    {% if is_state('sensor.moon', 'Waxing crescent') %}
      /local/images/waxing-crescent-moon.png
    {% endif %}
That looks wrong to me, it should look like this…
    sensors:
      moons:
        friendly_name: "Moon Type"
          {% elif is_state('sensor.moon', 'Waning crescent') %}
          {% elif is_state('sensor.moon', 'Waxing crescent') %}
          {% endif %}
Remember you can check these in the template editor :slight_smile:
  sensors:
    moon_phase:
      friendly_name: "Moon Phase"
      value_template: >
           'New Moon'
           'Waning Moon'
        {%elif is_state('sensor.moon', 'Waxing crescent') %}
           'Waxing Moon'
        {% endif %}
           /local/moon_new.png
           /local/moonwane.png
           /local/moonwax.png
        {% endif %}
