This is exactly what I am trying to accomplish did anyone get it done?
No, I never managed to do it.
…actually, I’ve just found out how to do this
If you look at this info on Template Switches (bottom of the page) you can use ‘entity_picture_template’ to change the images.
This is what I have but does not seem to change the icon to entity
sensor.moon:
friendly_name: Moon
entity_picture_template: >-
{% if is_state('sensor.moon', 'New moon') %}
/local/images/new-moon.png
{% if is_state('sensor.moon', 'Waning crescent') %}
/local/images/waning-crescent-moon.png
{% if is_state('sensor.moon', 'Waxing crescent') %}
/local/images/waxing-crescent-moon.png
That looks wrong to me, it should look like this…
sensors:
moons:
friendly_name: "Moon Type"
{% elif is_state('sensor.moon', 'Waning crescent') %}
{% elif is_state('sensor.moon', 'Waxing crescent') %}
Remember you can check these in the template editor
sensors:
moon_phase:
friendly_name: "Moon Phase"
value_template: >
'New Moon'
'Waning Moon'
{%elif is_state('sensor.moon', 'Waxing crescent') %}
'Waxing Moon'
/local/moon_new.png
/local/moonwane.png
/local/moonwax.png
Awesome thank you! Where are you getting your moon png’s from I like them better than mine lol
I just did a google search for phases of the moon pictures
can this be used in the customize section to modify an existing binary sensor or do I have to create a template sensor for it to work?
No idea I just used a template sensor
Alrighty then. Thanks!
I just gave it a try by creating a template binary sensor.
It didn’t work but I’m not sure why.
Here is the code in my binary_sensors.yaml:
sensors:
n_gd_pos_template:
friendly_name: "North Garage Door Position"
device_class: opening
value_template: "{{ is_state('binary_sensor.garage_door_north_position_sensor', 'on') }}"
{% if is_state('binary_sensor.garage_door_north_position_sensor', 'off') %}
/local/my-garage-closed.png
{% elif is_state('binary_sensor.garage_door_north_position_sensor', 'on') %}
/local/my-garage-open.png
extra_data_template: Battery Level ${(entities['sensor.batt_garagedoor1'].state)}%
I ran the template through the checker and it came up with the correct response so I know that part is good.
I get this error in the log:
2018-02-11 17:26:20 ERROR (MainThread) [homeassistant.config] Invalid config for [binary_sensor.template]: [entity_picture_template] is an invalid option for [binary_sensor.template]. Check: binary_sensor.template->sensors->n_gd_pos_template->entity_picture_template. (See ?, line ?). Please check the docs at https://home-assistant.io/components/binary_sensor.template/
I’ve checked the docs and according to that “entity_picture_template” is indeed a valid option:
Am I missing something here?
Try getting rid of the above line? Other than that I don’t see where yours is different from mine.
Yeah I already tried that. Neither way works.
Looks like I need to keep digging…
The only other thing that’s different is the device_class line.
The docs say that is OK too but I removed that line just to be sure.
Same result.
It needs to be in sensors not binary_sensors maybe?
Both should support entity_picture_template. At least according to the docs…
I tried it anyway…
same result only now the error is in sensor not binary_sensor
2018-02-11 18:46:54 ERROR (MainThread) [homeassistant.config] Invalid config for [sensor.template]: [device_class] is an invalid option for [sensor.template]. Check: sensor.template->sensors->n_gd_pos_template->device_class. (See ?, line ?). Please check the docs at https://home-assistant.io/components/sensor.template/
EDIT: never mind different error…
Last thing I can think of is the - in the png name, try it with an underscore, after that I’m out of ideas
