Change from qwerty to azerty in command line
I’m looking for a solution to switch from qwerty to Azerty when I’m on the command line.
Do you know the solution?
Thank you
Hi, I have the same issue. Did you found the solution for an azerty keyboard?
Did you find the solution to switch from a Qwerty keyboard to an Azerty keyboard? There is indeed the command “setxkbmap fr”, but this one does not work under the prompt ha!
With a keyboard configured in Qwerty: how do you get the “é” key?
Hi, I did not find a solution either.
I want to know this too!
No Solution?
Not yet it seems. We azerty users seem to be a global minority.
ah…
A chance to get an update ? . :smiling_face:
Still not working
