HI,
I’ve succesfully managed to show a group based on an input_select using the group.set_visibility service depending on the selection made.
Since it is a ‘developers’ group i only want to show when in developer mode, i would have hoped it to be possible to change the View state of that group also, and show the group as a Tab/View. I’ve been experimenting (check the ## in below script) with the group.set but without any luck…
I can get the group to show when stating View: true , but then it always shows, even when the group itself is set to have group.set_visibilty: false.
How could i do this, preferably within the below code:
# Mode Developer
mode_developer:
alias: Developer mode selected
sequence:
- service: input_select.select_option
entity_id: input_select.ha_mode
option: Developer
- service: group.set_visibility
entity_id: group.developer
visible: True
# - service: group.set
# data:
# object_id: Developer
# view: true
# visible: true
- service: notify.ios_telefoonmhb
title: Mode Selection
message: "Ready for some serious development!"
I am seriously confused about the object_id because of the feedback the dev-tools give me in Hassio…suggesting i should try “groupdeveloper” which does nothing, and that is to be expected of course since it doesn’t exist…
group:
developer:
icon: mdi:developer-board
# view: true
entities:
- script.mode_normal
- script.reload_summary
- script.refresh
- script.reload_frontend
- script.restart_ha
- group.developer_links
Please have a look and see what I could do to make this work.
Thanks,
Marius
