Change HA Color Wheel to display temperature palette
Hello there !
I am trying to achieve a new color wheel based on the original Home assistant color picker which would look like this basically :
I spent one whole day trying to copy the Home assistant color picker and modify it to change its behaviour.
I am using the Light Entity Card to implement this and i tried to modify the last bit of the code :
      <div class='light-entity-card__color-picker'>
        <ha-color-picker
          id="${this.generateColorPickerId(t)}"
          class='control color'
          saturation-segments=${this._saturationSegments}
          hue-segments=${this._hueSegments}
          throttle=500
          @colorselected=${e=>this.setColorPicker(e,t)}
        </ha-color-picker>
      </div>
with my one personal tag for the color picker (ha-color-picker-temp) :
        <ha-color-picker-temp
          throttle=500
        </ha-color-picker-temp>
      </div>
This does not recognize my custom ha-color-picker-temp. :frowning:
To be able to use these tags, I made sure that I put the line customElements.define("ha-color-picker-temp", HaColorPickerTemp); at the end of my custom ha-color-picker.
I hope this is clear !
Do you guys have any idea on how to make this work ?
Thanks a lot if you take the time to help me !!
