Hi everyone,
I hope, this is the right category for my question. I freshly installed HAOS on a cloud server (please no discussion about if this makes sense or not ^^) and now get an update notification from HAOS 10.2 to 10.3. However, if I cluck on “install” it works for a while, but nothing happens.
When I try “ha os update” on the CLI, I get “processing” for a while and then the following error:
Error: Can't fetch OTA update from https://github.com/home-assistant/operating-system/releases/download/10.3/haos_generic-x86-64-10.3.raucb: Connection timeout to host https://objects.githubusercontent.com/github-production-release-asset-2e65be/115992009/4156f348-1794-46ca-af57-66ccf04071e1?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAIWNJYAX4CSVEH53A/20230621/us-east-1/s3/aws4_request&X-Amz-Date=20230621T065716Z&X-Amz-Expires=300&X-Amz-Signature=94ce94ae42dcd75dc659bb3493e41ffb6c66c9a1a5fe96fc2060be7eee9500f1&X-Amz-SignedHeaders=host&actor_id=0&key_id=0&repo_id=115992009&response-content-disposition=attachment%3B%20filename%3Dhaos_generic-x86-64-10.3.raucb&response-content-type=application/octet-stream
My network connection looks ok-ish, ping and nslookup work like a charm.
WGET for this file on github works, too.
But “ha network info” shows this:
docker:
address: 172.30.32.0/23
dns: 172.30.32.3
gateway: 172.30.32.1
interface: hassio
host_internet: true
interfaces:
- connected: true
enabled: true
interface: enp0s10
ipv4:
address:
- 10.106.0.6/32
gateway: 10.106.0.1
method: static
nameservers:
- 8.8.8.8
- 1.1.1.1
- 8.8.4.4
ready: true
supervisor_internet: false
The problem seems to be that docker is using an MTU of 1500 per default, whileas my cloud server requires 1450 or less.
2: enp0s10: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1450 qdisc fq_codel state UP qlen 1000
link/ether 86:00:00:4c:9b:a7 brd ff:ff:ff:ff:ff:ff
3: docker0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP
link/ether 02:42:07:a1:62:70 brd ff:ff:ff:ff:ff:ff
Therefore it is possible to ping the update address from within the supervisor container, while it is not possible to wget the update file:
bash-5.1# ping objects.githubusercontent.com
PING objects.githubusercontent.com (185.199.108.133): 56 data bytes
64 bytes from 185.199.108.133: seq=0 ttl=54 time=7.974 ms
64 bytes from 185.199.108.133: seq=1 ttl=54 time=4.865 ms
64 bytes from 185.199.108.133: seq=2 ttl=54 time=4.629 ms
64 bytes from 185.199.108.133: seq=3 ttl=54 time=4.735 ms
64 bytes from 185.199.108.133: seq=4 ttl=54 time=4.662 ms
^C
--- objects.githubusercontent.com ping statistics ---
5 packets transmitted, 5 packets received, 0% packet loss
round-trip min/avg/max = 4.629/5.373/7.974 ms
bash-5.1# wget https://github.com/home-assistant/operating-system/releases/download/10.3/haos_generic-x86-64-10.3.raucb
Connecting to github.com (140.82.121.4:443)
Connecting to objects.githubusercontent.com (185.199.108.133:443)
<HANG>
pfSense Packet Capture:
17:41:16.825692 IP 10.106.0.6.59488 > 185.199.108.133.443: tcp 0
17:41:16.829946 IP 185.199.108.133.443 > 10.106.0.6.59488: tcp 0
17:41:16.831193 IP 10.106.0.6.59488 > 185.199.108.133.443: tcp 0
17:41:16.859241 IP 10.106.0.6.59488 > 185.199.108.133.443: tcp 331
17:41:16.863313 IP 185.199.108.133.443 > 10.106.0.6.59488: tcp 0
17:41:16.865745 IP 185.199.108.133.443 > 10.106.0.6.59488: tcp 1420
17:41:16.865768 IP 185.199.108.133.443 > 10.106.0.6.59488: tcp 1420
17:41:16.865774 IP 185.199.108.133.443 > 10.106.0.6.59488: tcp 972
17:41:16.866412 IP 10.106.0.6 > 185.199.108.133: ICMP 10.106.0.6 unreachable - need to frag (mtu 1450), length 556
17:41:16.866440 IP 10.106.0.6 > 185.199.108.133: ICMP 10.106.0.6 unreachable - need to frag (mtu 1450), length 556
17:41:16.866658 IP 10.106.0.6.59488 > 185.199.108.133.443: tcp 0
17:41:16.885585 IP 185.199.108.133.443 > 10.106.0.6.59488: tcp 1420
17:41:16.885809 IP 10.106.0.6 > 185.199.108.133: ICMP 10.106.0.6 unreachable - need to frag (mtu 1450), length 556
17:41:17.125617 IP 185.199.108.133.443 > 10.106.0.6.59488: tcp 1420
17:41:17.125911 IP 10.106.0.6 > 185.199.108.133: ICMP 10.106.0.6 unreachable - need to frag (mtu 1450), length 556
17:41:17.597619 IP 185.199.108.133.443 > 10.106.0.6.59488: tcp 1420
17:41:17.597954 IP 10.106.0.6 > 185.199.108.133: ICMP 10.106.0.6 unreachable - need to frag (mtu 1450), length 556
17:41:18.557753 IP 185.199.108.133.443 > 10.106.0.6.59488: tcp 1420
17:41:18.558029 IP 10.106.0.6 > 185.199.108.133: ICMP 10.106.0.6 unreachable - need to frag (mtu 1450), length 556
17:41:20.445729 IP 185.199.108.133.443 > 10.106.0.6.59488: tcp 1420
From within the homeassistant container (running on the host network), both ping and wget are successful.
Any idea, how I can change the HAOS docker´s MTU from 1500 to 1450 and persist that setting? I tried and search pattern on Google I could think of, but wasn´t successful. Creating /etc/docker/daemon.json wasn´t successful, as the file doesn´t persist after a restart.
Thank you in advance,
Joachim
