EDIT / UPDATE: I incorrectly thought that during setup HAOS generates its own SSL certificates, I’m finding out that’s not the case. So my question below is Irrelevant / wrong and this can be closed out (ill just use lets enc to make my own certs, and change port , and point ssl arguments in config.yaml to the new lets enc generated certs.)
my HAOS is internal access only (local network, If I’m ever external I access it over a VPN). so no pubIP port forwards, on router, at all.
Im trying to change https://10.6.6.200:8123 to https://10.6.6.200:443 (or really https://10.6.6.200 which is same as :443)
I dont want to use nginix, nor nginx proxy manager. Im trying to avoid lets encrypt add-on, as i want to use the default certs that are already in HAOS, somewhere (im assuming they were generated a few days ago when i installed / first setup HAOS, which is running on esxi). I say this as SSL is working if i visit via the default port: https://10.6.6.200:8123
i have edited config/configuration.yaml , and always do “check configuration” before restarting.
I think my question here is, what is the path to the default HAOS ssl certs? (ie the ones that are created at setup and used for :8123 ?). I have tried find / -ipath "*lets*"
since the default ssl certs used by default :8123 have to be somewhere (but i cant find them).
this works (but wo SSL ofcouse):
cat config/configuration.yaml
default_config:
http:
server_port: 80 # Change this to your desired HTTPS port
#ssl_certificate: /ssl/fullchain.pem # Path to your SSL certificate
#ssl_key: /ssl/privkey.pem # Path to your SSL key
and then in webBrowser use http://10.6.6.200 (if i try https:// i get SSL SSL_ERROR_RX_RECORD_TOO_LONG
im assuming because im not pointing to the ssl cert / key via ssl_key:
and ssl_certificate:
thus if i can point those 2x config vars to the default HAOS cert/key, i think i should be in good shape.
thank you for your time.
