It’s a very basic question I think, but I cannot seem to get the right answer via existing topics, Google or ChatGPT, so my question is: How do I adjust the Home Assistant URL (Default = http://homeassistant.local:8123) via the CLI?
What are you trying to actually do.
Url is a function of DNS and you may need to specify a name for SSL. You don’t do it in the cli
You will have to change the hostname. You can do that from the UI:
Settings → Network → Hostname
Or use the supervisor options --hostname yournewhostnamehere
Thanks that seems to be the thing I’m searching for. When I add a name after --hostname
, I get the response:
Error: extra keys not allowed @ data ['hostname' ]. Got 'habackup'
Can I not just put a name here?
No clue as to why it wont accept. Tried it on my test system and other options will accept, just not the hostname. Perhaps just do it from the UI
Ok, so there is no method to set the hostname/URL via the CLI?
I was able to set it using:
ha host options --hostname newhostname.lan
