I would like to change the default home screen on my android smartphone by location.
My example is to have to different home screens, one for work, the other for normal.
I already have the home screens made, but would like to change the default if im at work, now i always have to swipe left to get the home screen i want.
I have a Samsung S21 and tried with bixby routines but i cant find anything for home screen.
Hope someone had the same ideia and already found a solution
sounds like a feature request for the HA frontend, or you can just use android shortcuts and select the appropriate shortcut when you want to open the app. You can set different shortcuts for each dashboard.
I think you dont understand my question.
i want to change the default home screen of my smartphone, not on the home assistant app.
i did more research and looks like is not possible or nobody ever tryed it.
