i’m new to home assistant and i’ve googled but its not that easy to google for state switch
i’ve got a homegear switch and in the ui it shows its on when is off and vice versa.
how can i change that?
thanks for your help
regards
celevra
regards
celevra
Looks like you are looking for this:
@danielperna84
Yes thats the component i’m using
@azeroth12
Thank you, i will Look into this
In that case you could work around via template (like azeroth12 said). But having an inverted switch actually indicates, that you either haven’t connected the actuator correctly, or Homegear allows to internally invert the logic that the switch is exposing. The HomeMatic component is designed to read True as on and False as off. That’s the default when you buy such a switch, and there’s no integrated method for the HomeMatic component to change this.
@danielperna84
you are totally right!
it didn’t felt right to change it via template and i looked at the switch it self. Seems you can connect it in two ways
i’ve corrected it and now everything works as expected.
Thanks for your help
regards
