Change humidity/temperature data on weather.home
Hello everyone,
Is there a possibility to add a custom value/sensor on the default wheater.home layout?
Because I have some humidity and temperature sensors more accurate than the defaults one on wheather.home and I want also mantain forecast.
Use the Template Weather Provider. Description found in the integrations.
Thank you!
