Hi, I have a newly installed HA instance and just started configuring. I’ve been able to configure some Zigbee switches, camera’s, etc, and can send and receive mqtt messages. What I’m searching for is a possibility to change an icon (or icon color) based on received mqtt message content.
So let’s say, for simplicity, the topic/payload is:
topic: Room_1_humidity ; payload: HIGH (or LOW)
I want to have just an icon showing an arrow UP or DOWN
I think it is simple, but I have not been able to find out how this should be achieved.
Thanks!
Then, for the sensor’s icon that you want to change, use a template for its icon (docs from the template sensor definition) that adjusts based on the state of this sensor.
Come back to use with the code that you have tried (correctly formatted with the </> button) if you get stuck.
@Troon, thx for replying. This probably will be a step-by-step process as for me the documentation leaves many open ends. My first step is that I’ve been able to create an entry in configuration.yaml which creates an entity which can be selected in an entity-card:
mqtt:
binary_sensor:
- name: TestSensor
state_topic: My/Topic/result
unique_id: TestSensor
payload_on: ON
payload_off: OFF
