Change icon colour in entity on custom card, nothing i try works
I have the following card yaml, using card mod and multiple entity row.
I want the icons to change colour depending on the state of the attributes.
type: entities
entities:
  - entity: fan.lounge_fan
    type: custom:multiple-entity-row
    toggle: true
    entities:
      - entity: sensor.lounge_fan_temperature
      - attribute: percentage
        unit: '%'
    show_state: false
    unit: '%'
    icon: mdi:fan-plus
    entities:
      - icon: mdi:fan-speed-1
        tap_action:
          action: call-service
          service: fan.set_percentage
          service_data:
            entity_id: fan.lounge_fan
            percentage: 25
      - icon: mdi:fan-speed-2
        tap_action:
          service_data:
            percentage: 50
      - icon: mdi:fan-speed-3
        tap_action:
          service_data:
            percentage: 75
      - icon: mdi:fan-plus
        tap_action:
          service_data:
            percentage: 100
    attribute: oscillating
    icon: mdi:rotate-3d-variant
    show_state: false
    entities:
      - attribute: oscillating
      - icon: mdi:bullseye
        tap_action:
          service: fan.oscillate
          service_data:
            oscillating: false
      - icon: mdi:rotate-3d-variant
        tap_action:
          service_data:
            oscillating: true
    attribute: preset_mode
    icon: mdi:cog-pause
    entities:
      - icon: mdi:tailwind
        tap_action:
          service: fan.set_preset_mode
          service_data:
            preset_mode: normal
      - icon: mdi:forest
        tap_action:
          service_data:
            preset_mode: nature
      - icon: mdi:sleep
        tap_action:
          service_data:
            preset_mode: sleep
title: Fan
show_header_toggle: false
state_color: true
how can i change the icons colour depending on what the state of the attribute is.
I want to change the icon that you touch to change the speed and swing settings. Not the one to the left of the card.
The ones on the right side of the card.
Ive tried everything and cant figure it out.
The 1st post of card_mod topic → post with links to styles → post about multiple-entity-row → your required code
Thank you so much. i never would have guessed that
My code
type: entities
entities:
    toggle: true
    state_color: true
    entities:
    show_state: false
    unit: '%'
    icon: mdi:fan-plus
    state_color: true
    style:
      hui-generic-entity-row:
          div.entity:nth-child(1) state-badge {
            color: {% if is_state_attr('fan.lounge_fan', 'percentage', 25) %} var(--primary-color) {% endif %};
          div.entity:nth-child(2) state-badge {
            color: {% if is_state_attr('fan.lounge_fan', 'percentage', 50) %} var(--primary-color) {% endif %};
          div.entity:nth-child(3) state-badge {
            color: {% if is_state_attr('fan.lounge_fan', 'percentage', 75) %} var(--primary-color) {% endif %};
          div.entity:nth-child(4) state-badge {
            color: {% if is_state_attr('fan.lounge_fan', 'percentage', 100) %} var(--primary-color) {% endif %};
    entities:
        tap_action:
          service_data:
            percentage: 25
        tap_action:
          service_data:
            percentage: 50
        tap_action:
          service_data:
            percentage: 75
        tap_action:
          service_data:
            percentage: 100
    show_state: false
    state_color: true
    style:
            color: {% if is_state_attr('fan.lounge_fan', 'oscillating', false) %} var(--primary-color) {% endif %};
            color: {% if is_state_attr('fan.lounge_fan', 'oscillating', true) %} var(--primary-color) {% endif %};
    entities:
        tap_action:
          service_data:
            oscillating: false
        tap_action:
          service_data:
            oscillating: true
    icon: mdi:cog-pause
    show_state: false
    state_color: true
    style:
            color: {% if is_state_attr('fan.lounge_fan', 'preset_mode', 'normal') %} var(--primary-color) {% endif %};
            color: {% if is_state_attr('fan.lounge_fan', 'preset_mode', 'nature') %} var(--primary-color) {% endif %};
            color: {% if is_state_attr('fan.lounge_fan', 'preset_mode', 'sleep') %} var(--primary-color) {% endif %};
    entities:
        tap_action:
          service_data:
            preset_mode: normal
      - icon: mdi:forest
        tap_action:
          service_data:
            preset_mode: nature
      - icon: mdi:sleep
        tap_action:
          service_data:
            preset_mode: sleep
title: Fan
state_color: true
And the Image
Alternatively - use a stock “styles::color: something” option and place the whole row inside config-template-card.
