What is the syntax for updating an input boolean from an automation rule? Something like this:
automation:
platform: time
hours: 16:00
input_boolean.school_day = "on"
automation:
platform: time
hours: 16:00
I recommend to take a look at actions
By the way, your automation should look like this:
automation:
- alias: Turn on school day
platform: time
after: "16:00"
service: homeassistant.turn_on
entity_id: input_boolean.school_day
Thanks, this is what I was looking for. I had missed the documentation on “homeassistant.turn_on”.
Follow-up question. Is there a way I can do the same thing with an “Input Select”? It does not look like “homeassistant.turn_on” would work, since the values are not on/off.
I think you can use:
service: input_select.select_option
entity_id: input_select.your_input_select
option: "your option"
Thanks, that worked as well. Could not find this anywhere in the documentation.
