Change Int value from sensor to text
Hi, im new in Home Assistant, i have a Chinese Thermostat. I figure how to create a MQTT sensor to get the state of curent temp etc. In the web UI i want to change the state 1 or 0 to something like Running or Shutdown.
/ Status du Thermostat Chambre Maitre On=1 Off=0
  • platform: mqtt
    name: “Chambre Maitre Thermostat Allume”
    state_topic: “/broadlink/4eae9f34ea34/power”
    retain: true
    / Température demandé Chambre Maitre
  • platform: mqtt
    name: “Chambre Maitre Thermostat Temperature Voulu”
    state_topic: “/broadlink/4eae9f34ea34/thermostat_temp”
    unit_of_measurement: ‘ºC’
    retain: true
    / Température Actuel Chambre Maitre
  • platform: mqtt
    name: “Chambre Maitre Thermostat Temperature Actuel”
    state_topic: “/broadlink/4eae9f34ea34/room_temp”
    retain: true
    / Mode du Thermostat Chambre Maitre Automatique=1 Manuel=0
  • platform: mqtt
    name: “Chambre Maitre Thermostat Mode Automatique”
    state_topic: “/broadlink/4eae9f34ea34/loop_mode”
    retain: true
    / Status du thermostat Chambre Maitre Actif=1 Inactif=0
  • platform: mqtt
    name: “Chambre Maitre Thermostat En-Marche”
    state_topic: “/broadlink/4eae9f34ea34/active”
    retain: true
Temp
