Hey together,
I changed the IP adress of my Unify Controller App. Therefore, my Unifi Network Integration correctly cannot connect anymore.
But: Where can I change the IP Adress for the Integration? I can’t find it on the frontend and in the configuration files. I really would like to not to setup all the devices and entities again…
Hope, somebody can help, thank you in advance!
Stefan
Figured it out myself after a while. Just add the integration a second time with the new IP and credentials and the exisiting integration is updated.
So are you saying that you installed it a second time, entered the IP and server info, then the initial instance was updated? Did you remove the second instance after done? Sounds like an overlap in configuration that you were able to take advantage of if I’m understanding right.
@jriker1 i added the integration A second Time and added my new configuration, but it worked out to be like an update.
I did Not have to remove a second installation, as there was none.
Just in case anyone finds themselves needing the same - I can confirm this is still the right way to “fix” a Unifi Network integration that stops being able to authenticate.
I just added ‘protect’ to my HA, and for whatever reason, the Network integration crapped out. I just “readded” the integration, and it connected again (no second instance of the integration).
