Change language of a timestamp template sensor
I´ve got a template sensor telling me when it was last vacuumed. Is there a way to change the language of the day and month to norwegian?
  sensors:
    siste_stovsuger_start:
      friendly_name: 'Sist gang støvsugd'
      value_template: '{{ (as_timestamp(states.sensor.roborock_vacuum_a15_last_clean_start.last_changed)) | timestamp_custom("%A, %d. %B %H:%M") }}'
Gives me:
Monday, 05. December 17:22
and I would like
Mandag 05. Desember 17:22
I was under the same impression, apparently it is not. You may adapt this snippet to achieve your goal (same idea for months)
template:
  - sensor:
    - name: jour_fr
      unique_id: 9dd5782d-83c4-401c-afcf-5cd83232bde7
      state: >
        {% set jour = ["Dimanche", "Lundì", "Mardì", "Mercredì", "Jeudi", "Vendredì", "Samedi"] %}
        {% set jour = jour[now().weekday()] %}
        {{jour}}
So with this one I can use it to give me when an automation was last triggered:
{% set t = state_attr('automation.automatisk_lys_bad_2_etg', 'last_triggered') %}
{{ "%s %d. %s kl %02d:%02d" %
   (["Mandag","Trisdag","Onsdag","Torsdag","Fredag","Lørdag","Søndag"][t.weekday()],
   t.day,
   ["Januar","Februar","Mars","April","Mai","Juni","Juli","August","September","Oktober","November","Desember"][t.month-1],
   t.hour,
   t.minute) }}
But how can I make the same thing work with a sensor or light, which doesn’t have the attribute “last_triggered”?
Entities have a last_changed property that can be accessed using the state object:
{{ states.light.kitchen_light.last_changed }}
Tried this:
{% set t = states('roborock_vacuum_a15_last_clean_start.last_changed') %}
   t.day,
   t.hour,
   t.minute) }}
Just gives me:
UndefinedError: 'str object' has no attribute 'weekday'
You used the states() function instead of the state object method I showed in my previous post… and your entity is missing its domain.
{% set t = states.sensor.roborock_vacuum_a15_last_clean_start.last_changed %}
   t.day,
   t.hour,
   t.minute) }}
Aha!
Thank you! Did the trick :smiley:
