Change language on specific integrations
My language on Home Assistant is English, but I want my weather forecast to be in another language. When I change language, the text “Rainy” from the attached snip changes to the correct language, but I only want the weather forecast to be in norwegian, and everything else like settings etc. to be in english. Is it possible to change language on specific integrations?
I use the default Met.no for weather.
Any luck on solution??
Did not see your post before now… but I started using clock-weather-card from hacs instead. It supports many different languages.
