Change LCD Text with Home Assistant switch problem
Hi all!
Im trying to create a Kiln temperature sensor for my wife with an lcd display. One of the functions I want is to create a timer that starts when a switch is turned on in home assistant. And then display the time that has passed on the lcd screen.
EDIT: At this time I don’t have a timer configured yet. I just want the switch to change the text on the LCD screen. (One problem at the time, right?)
The problem is that whenever i turn on the switch in home assistant nothing happens and the switch turns itself back off.
What am I doing wrong?
This is my config:
esphome:
  platform: ESP8266
  board: nodemcu
wifi:
  ssid: !secret ssid
  password: !secret ssid_pass
# Enable logging
logger:
# Enable Home Assistant API
api:
  password: !secret api_pass
ota:
  password: !secret ota_pass
# SPI BUS HUB
spi:
  miso_pin: D5 #MISO = SO
  clk_pin: D6 #SCk
i2c:
  sda: D2
  scl: D1
  - platform: max31855
    name: "Kiln Temperature"
    cs_pin: D7 #CS
    update_interval: 30s
  - platform: wifi_signal
    name: "Kiln Sensor WiFi signal"
    update_interval: 60s
  - platform: uptime
    name: "Kiln Sensor uptime"
text_sensor:
  - platform: version
    name: "Kiln Sensor ESPHome version"
time:
  - platform: homeassistant
switch:
    name: "Kiln Timer Switch"
display:
  - platform: lcd_pcf8574
    dimensions: 20x4
    address: 0x27
    lambda: |-
      it.strftime(12,0, "%H:%M:%S", id(homeassistant_time).now());
      it.printf(0, 1, "Oven: %.1f C", id(kiln_temp).state);
      it.printf(0, 2, "--------------------");
      if (id(start_stop_timer).state) {
        it.print(0, 3, "state: ON");
      } else {
        it.print(0, 3, "state: OFF");
You might need to show us the timer configuration in home assistant?
At this time I don’t have a timer configured yet. I just wanted to check whether the text on the LCD screen would change when I toggle the switch in the front end.
I configured a switch in the ESP config:
switch:
This should change the text on the screen:
display:
    lambda: |-
      } else {
But on the LCD nothing happens and the switch in the front end turns itself back off after a second or two.
Is there really no-one who can help?
Your switch is not ok. Try setting optimistic to true.
I created this issue. https://github.com/esphome/issues/issues/399
Thanks! This fixed it
