Change Light Color based on who is home
Hi, I’m trying to set up a flow that changes the RGB LED on my BRUH sensor. Running Hassio on OpenMediaVault in a docker container.
For example:
If person1 is home -> LED = Red
If person2 is home -> LED = Blue
If both are home -> LED = Purple
If no one is home -> LED = off
I’ve created a group with person1 and person2 in there and the all: true flag set so if both users are home, the group entity is “home” but if one of them is missing, the group is listed as away.
Also I’m trying to use the light scheduler to turn on the LED at 6:00am and off at Midnight but that’s a bonus feature right now
Is there a simple way in Node-Red to handle gathering states from multiple entities (sensors or device trackers) and change the lights accordingly?
I imagine there is a simple way to accomplish this with writing a python script AppDaemon but my preference is to do this in node-red.
Thanks for any suggestions!
[{"id":"ca2ba311.83e5","type":"function","z":"ffbd7f06.4a014","name":"","func":"if (msg.payload.length === 0) {\n    msg.payload.service = \"turn_off\";\n    return msg;\n}\n\nlet color = \"blue\" // default to person2\nif (msg.payload.length == 2) {\n    color = \"purple\";\n} else if (msg.payload[0].entity_id == \"device_tracker.person1\") {\n    color = \"red\";\n}\n\nmsg.payload = {\n    data: {\n        \"color_name\": color\n    }\n};\n\nreturn msg;","outputs":1,"noerr":0,"x":722,"y":784,"wires":[["c73875e7.3076d8"]]},{"id":"f4ee87a5.83de18","type":"ha-get-entities","z":"ffbd7f06.4a014","server":"2dad33ee.42bf5c","name":"","rules":[{"property":"entity_id","logic":"includes","value":"device_tracker.person1,device_tracker.person2","valueType":"str"},{"property":"state","logic":"is","value":"home","valueType":"str"}],"output_type":"array","output_empty_results":true,"output_location_type":"msg","output_location":"payload","output_results_count":1,"x":566,"y":784,"wires":[["ca2ba311.83e5"]]},{"id":"c73875e7.3076d8","type":"api-call-service","z":"ffbd7f06.4a014","name":"Light","server":"2dad33ee.42bf5c","service_domain":"light","service":"turn_on","data":"{\"entity_id\":\"light.light\"}","render_data":false,"mergecontext":"","output_location":"payload","output_location_type":"msg","x":866,"y":784,"wires":[[]]},{"id":"5c072cb7.c8c374","type":"server-state-changed","z":"ffbd7f06.4a014","name":"","server":"2dad33ee.42bf5c","entityidfilter":"device_tracker.person1,device_tracker.person2","entityidfiltertype":"substring","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"x":248,"y":784,"wires":[["f4ee87a5.83de18"]]}]
Another option
[{"id":"3ace1d47.60aa72","type":"function","z":"ffbd7f06.4a014","name":"","func":"//If person1 is home -> LED = Red\n//If person2 is home -> LED = Blue\n//If both are home -> LED = Purple\n//If no one is home -> LED = off\nif (msg.payload.length === 0) return [null, msg];\n\nlet color = \"blue\" // default to person2\nif (msg.payload.length == 2) {\n    color = \"purple\";\n} else if (msg.payload[0].entity_id == \"device_tracker.person1\") {\n    color = \"red\";\n}\nmsg.color = color;\nreturn [msg, null];","outputs":2,"noerr":0,"x":770,"y":896,"wires":[["fddf289d.e6e4a8"],["b9c08f14.0c6aa"]]},{"id":"aed9fda.d304a","type":"ha-get-entities","z":"ffbd7f06.4a014","server":"2dad33ee.42bf5c","name":"","rules":[{"property":"entity_id","logic":"includes","value":"device_tracker.person1,device_tracker.person2","valueType":"str"},{"property":"state","logic":"is","value":"home","valueType":"str"}],"output_type":"array","output_empty_results":true,"output_location_type":"msg","output_location":"payload","output_results_count":1,"x":614,"y":896,"wires":[["3ace1d47.60aa72"]]},{"id":"b9c08f14.0c6aa","type":"api-call-service","z":"ffbd7f06.4a014","name":"Turn off Light","server":"2dad33ee.42bf5c","service_domain":"light","service":"turn_off","data":"{\"entity_id\":\"light.light\"}","render_data":false,"mergecontext":"","output_location":"payload","output_location_type":"msg","x":934,"y":944,"wires":[[]]},{"id":"fddf289d.e6e4a8","type":"api-call-service","z":"ffbd7f06.4a014","name":"Set color","server":"2dad33ee.42bf5c","service_domain":"light","service":"turn_on","data":"{\"entity_id\":\"light.light\",\"color_name\":\"{{color}}\"}","render_data":true,"mergecontext":"","output_location":"payload","output_location_type":"msg","x":924,"y":896,"wires":[[]]},{"id":"f81b3b78.116248","type":"server-state-changed","z":"ffbd7f06.4a014","name":"","server":"2dad33ee.42bf5c","entityidfilter":"device_tracker.person1,device_tracker.person2","entityidfiltertype":"substring","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"x":296,"y":896,"wires":[["aed9fda.d304a"]]}]
Dude!!! Thank you so much!!! I’m using the first flow and it seems very solid
