Change light colour temperature without turning the light on
Using Zigbee2Mqtt is possible to change colour temperature in a light without changing its state. Therefore, I can set a light’s temperature to warm and keep it off. And them, when I turn it on, it is warm.
However, I can’t do that using directly Home Assistant. So, this is actually a Home Assistant limitation, as the zigbee ligths allow that, but Home Assistant doesn’t AFAIK.
Is there a way not using Zigbee2Mqtt directly (for instance using different integrations) to change a light colour temperature without turning it on?
