Is it possible to change the switch icons from the lightning bolts to something like shown for “Volume Up Down”? If so how? I’ve searched but only found how to change the left icons, which I’ve done.
Thanks Clay
Thanks Clay
A hack for this:
I understand the “hack” using a template cover for this case, but if I want for example to use any mdi:icon, is this possible ?
you can use the custom_control settings available through custom-ui https://github.com/andrey-git/home-assistant-custom-ui/blob/master/docs/features.md#custom-controls
tbh, I havent done that, because I don’t have custom control items available. This doesn’t work with mid incons though.
see here: CustomUI - discussion thread
and a bit further down @andrey 's answer CustomUI - discussion thread
