Change Lovelace page from automation
I currently use HADashboard, which displays general info (weather, temperature etc) normally, but jumps to a video feed of my entrance when someone rings the doorbell. Is it possible to do the same with Lovelace, that is, change the current page from an automation?
I saw from the post regarding the Alarm Clock card that was here that it’s possible to call different tabs with /lovelace/1 or /lovelace/2 so with this in mind it should be doable to call a new page I believe?
Thank you, do you know how Home Assistant can “signal” this to the tablet running Lovelace? An alternative would be to use the conditional card, but it seems more right to dedicate a page to a function and jump between those automatically.
