Change MDI Icon and Color based on state
Hi all,
I’m using custom ui and i try to change the color and the icon of an entity based on its state.
I’ve tried the following code but it didn’t work:
    sensor.nas01_status:
      templates:
        icon: >
         if (state === 'good') return 'mdi:checkbox-marked-circle-outline';
         else return 'mdi:close-octagon';
        icon_color: >
         if (state === 'good') return 'rgb(67,167,47)';
         else return 'rgb(219,27,8)';
When I use an entity card to display the sensor I get the correct color and correct icon. When i change the
state to something else then good the color and the icon didnt change. When Im using a picture-glance card
I didnt even get the right color. Maybe someone of you can point me in a direction.
Thanks in Advance.
  custom_ui_state_card: state-card-custom-ui
  templates:
    icon: if (state === 'good') return 'mdi:checkbox-marked-circle-outline'; else return 'mdi:close-octagon';
    icon_color: if (state === 'good') return 'rgb(67,167,47)'; else return 'rgb(219,27,8)';
Sent too soon. The above needs to be in customize.yaml with
  customize_glob:
    sensor.*:
in your configuration.yaml
Cool, thank you that did the trick for mdi icons in entity cards. The bad news is that in glance picture cards it still didnt work:(
The View in Lovelace:
glance
But the entity view (when clicking on the icon) shows the correct color value:
entity
Hmm maybe its an issue with custom-ui.
