Hi.
I’m trying to convert the output value from an mqtt sensor.
This is the sensor:
- platform: mqtt
name: “MQTT Power Usage Play1”
state_topic: “homeseer/mcsMQTT/1st/Stue/StikkSonosP1/Power”
unit_of_measurement: ‘W’
This works fine and gives me an value:
I want to convert the comma to dot and that works find if I use this code in the dev-template:
"{{ states.sensor.mqtt_power_usage_play1.state | replace(',', '.') }}"
But how do I implement that in my config? I have read about value_template etc. but have not find the correct solution. Glad if anyone can help me with this.
